ACS5.1 System Alarm [Collector] Store failure (DCACSBGLR, TacacsAccounting)
Answered Question
Aug 13th, 2010
Recently I have deployed ACS5.1 at a customer location. We are often receiving the following Alarm in the inbox.
Cisco Secure ACS - Alarm Notification
          Severity: Critical
          Alarm Name                  System Alarm [Collector]
          Cause/Trigger                  Store failure (DCACSGKOL, TacacsAccounting)
          Alarm Details                   Please see Collector log for details
          Generated On                  Fri Aug 13 14:25:59 UTC 2010
Please suggest the solution to understand and get rid of this Alarm. Thankyou...
Correct Answer by jrabinow about 6 years 5 months ago
Been checking around and found following CDETS that seems to be related:
CSCte88357: ACS5.1 Tacacs Accounting Report missing few attributes due to NULL char
This issue certainly causes and alarm of store failure although I can't confirm this is precisely the same case.
If this is the issue a fix is available in Cumulative patch 5.1.0.44.3 available for download on CCO
Overall Rating: 5 (1 ratings)
Correct Answer
jrabinow Mon, 08/23/2010 - 22:32
madhankumar.g Mon, 08/30/2010 - 01:15
Hi irabinow,
The issue has been resolved after installing the patch suggested by you. Thanks a lot.
Madhan kumar.
ivanbarkic Thu, 11/11/2010 - 23:57
I have ACS v5.1.0.44 and still get:
Occurred At:Fri Nov 12 08:01:11 CET 2010
Cause:Store failure (AAA01, TacacsAccounting)
Details:Please see Collector log for details
It occures every 3-4 days.
madhankumar.g Fri, 11/12/2010 - 00:41
Install Cumulative patch 5.1.0.44.3 available for download on CCO, if you haven't done it yet. see if you get latest patch than this also. The error duration of 3-4 days gap may be because of the Suppression timer of similar errors, which is configurable under Alarm configuration.
ivanbarkic Fri, 11/12/2010 - 00:46
I see that v5.1.0.44.4 is available. Can I install that patch instead
of 44.3?
madhankumar.g Fri, 11/12/2010 - 00:51
You can install v44.1 followed by v44.2, then v44.3 and finally v44.4. This is how usually we upgrade ACS in incremental order.
ivanbarkic Fri, 11/12/2010 - 01:08
At the moment when I issue command show app ver acs:
Cisco ACS VERSION INFORMATION
Version : 5.1.0.44
Internal Build ID : B.2347
Does it mean that I don't have any patches yet?
ivanbarkic Fri, 11/12/2010 - 04:31
Well, yes. It didn't have any patches. I upgrade directly to version 5.1.0.44.4 and it seems OK. I will check in next couple of days if there will be same system error again. Thanks for your advices.
Related Content
