Caller Id
Aug 13th, 2010
I am installing a UC540 using a One Communications sip trunk.
My customer has multiple companies and would like to know which is being called, when answering the phones.  My plan was/is to create line appearances on the phones for each company.  However, the customer wants to see both the calling and called id to show on the display.  Is that possible?  If so, can I get a kick start on where to go to configure?
Jay
pro4ianyc Fri, 08/13/2010 - 06:30
You won't be able to show the called number when someone calls, but you can use a label to identify which line on your phone is which.
That way when someone calls 111-1111, it'll ring at line labeled 111-1111 with the caller's caller ID.
