UC560 at main site & SR520 + APs at remote
Aug 13th, 2010
We have a client who wants to have the following setup-
UC560 at main site
SR520 & 3 APs at remote site with company & guest WLAN access
Would you recommend a WLAN controller at the remote site with light APs or 3 standalone APs?
I have not had an opportunity to setup a WLAN controller behind a SR.  Do the two devices work well together?
greenturtlesteak Fri, 08/13/2010 - 07:56
This solution should work fine. You will need to create another VLAN at the remote site for the guest network and use lighweight APs. Autonomous APs will not register with a WLC.
Keep in mind that you won't be able to do a complete configuration with CCA as the WLC/LAP products are not designed to be managed by CCA.
Cole
