New script does not apply in the "application" Correctly
Answered Question
Aug 13th, 2010
I have created a new script
in Contact Center and when I add it to a application in contact center I notice I do not see all the prompts listed. Another one I have like it list everythign when the script is loaded inot the application. So image one I posted shows a script that is showing all the prompts and image 2 shows the one i just created and does not show them all like a MENU prompt and a couple other ones should be showing. I have attached the script I created also.
Correct Answer by Aaron Harrison about 6 years 6 months ago
The only parameters that will appear in the Application page are those that you have marked as parameters when you defined the variables. Have you done this? (I don't have CCX Editor to hand to check).. if not you can click the edit icon on the variable pane to set the property.
If you have done this, then do a refresh of the script - first from Script Management (click the refresh icon) and then do a refresh of the app from Application Management.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Fri, 08/13/2010 - 08:30
Aaron
DavidPeter Fri, 08/13/2010 - 11:13
That was great answer! Thanks! I can see them now but I have one more issue and maybe
should start a new post for it? I get a message stating "We are eperienc
ing a sytem problem" when I call the trigger. It should at least hit the menu right? I guess I am calling during business hours that I set up. I do not have queue logged in though but shouldnt it still just send me to the MENU ? Maybe I missing something in the script?
I re-added the screen shots also although they related to the original question that was answered.
thanks
Anthony Holloway Fri, 08/13/2010 - 09:07
Sorry but this has to be said: Do not paste screenshots inside of Microsoft Word Documents.  Open mspaint and paste it, then save as .png.
Aaron Harrison Fri, 08/13/2010 - 11:38
Best thing to do would be start a new thread for this problem as you suggsted.
That said, what you will be told is this:
- In CCX Editor (having succesfully logged on when running the editor) go to Toosl/Reactive Debug. Select your script and then set a timeout of 300 seconds. Dial the pilot, and the script will appear in the editor. You can then hit F10 repeatedly to step through the script execution and see where it fails.
If you can't figure out your error, start a new thread.
Aaron
