Publisher down - Steps of Reinstallation
Aug 13th, 2010
Hi all,
I am facing the current problem;
I have a CUCM cluster, version 6.1. The Publisher is down and I need to reinstall the CUCM on it.
What are the steps to do so? All I know is that I cannot replicate from the subscriber to the publisher.
Do I install normally and redo all the configuration?
Does it work if I do a backup on the Subscriber and restore on the Publisher?
I know it's not a hard task but I just don't know the exact steps.
Thank you
Overall Rating: 5 (5 ratings)
Rob Huffman Fri, 08/13/2010 - 08:40
Hi Mazen
Here is the related info for your
version. I'm hoping you have a DRS backup
Replacing the Publisher Node
Complete the following tasks to replace the Cisco Unified Communications Manager publisher server. If you are replacing a single server that is not part of a cluster, follow this procedure to replace your server.
Caution If you are replacing a publisher node in a cluster, you must also reinstall all the subscriber nodes and dedicated TFTP servers in the cluster, after replacing the publisher node.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/cluster/clstr611.html#wp87717
Cheers!
Rob
mazenelhourani Fri, 08/13/2010 - 09:04
Hi Rob,
Thank you for your reply.
Unfortunately, I don't have a DRS backup. The servers belong to a customer.
So from what I understood here, I should first reinstall the publisher and then reinstall the Subscriber.
I can do a backup for the Subscriber since it's still up and running. But since I don't have a publisher's backup, I will need to reconfigure it from 0. I wouldn't need to restore the subscriber, I'll just do the replication. Is that correct?
Thanks.
Mazen
Rob Huffman Fri, 08/13/2010 - 10:55
Hi Mazen
You are most welcome my friend
This is not a good situation, to be sure;
Unfortunately, I don't have a DRS backup. The servers belong to a customer. Not Good
So from what I understood here, I should first reinstall the publisher and then reinstall the Subscriber. That is the only way with a 6.x CUCM version
I can do a backup for the Subscriber since it's still up and running. But since I don't have a publisher's backup, I will need to reconfigure it from 0. I wouldn't need to restore the subscriber, I'll just do the replication. Is that correct? The DRS Backup would have to have been done from Pub. The Subs will have to be rebuilt after the Pub has been completed and replication can then take place.
Best of luck with this.
Cheers!
Rob
mazenelhourani Fri, 08/13/2010 - 13:13
Hi Rob,
Yeah I know it's a bad situation. It belongs to a customer and he called me for urgent support.
It's no problem, it's not a big configuration. So I can do it all back in one day.
This customer is a pain in the ass. When I first installed the cluster, they had a power failure. I told them to get a UPS. And replaced the primary (before installing a subscriber), and now again, the publisher is down after the UPS ran totally out of  power lol ( I got some linux errors regarding the file systems, the recovery didn't work at all!! it said the group descriptors look bad.. I am not gonna bother much with it, so I'll just reinstall).. Well, I have to be patient with that customer lol
Thanks Rob!
Rob Huffman Fri, 08/13/2010 - 14:04
Hi Mazen,
I must applaud your very calm, patient demeanor here It is
easy to get frustrated with clients, but without them where would we be?
+5 points for your very professional outlook.
Best of luck here my friend.
Cheers!
Rob
mazenelhourani Fri, 08/13/2010 - 14:28
Thanks Rob, it means to me when it comes from a professional like yourself.
Thanks for all the help, I'll keep you posted when I go on site on Monday!
Have a nice weekend.
Mazen
mazenelhourani Wed, 08/18/2010 - 10:46
Hi Rob,
Thank you! All went fine as planned.
By the way, you said in a previous post that for this version (6.1(1b)) you can't use the subscriber's configuration backup to restore it back later.
In later versions, we can do a backup/restore just on the publisher? Can we ever backup on the one of subscriber and restore on the publisher?
Thank you!
Rob Huffman Wed, 08/18/2010 - 11:31
Hi Mazen,
Great work my friend
The statement;
Should really say;
you can't use the subscriber's configuration backup to restore a Publisher/First Node later.
This statement carries across to all current CUCM versions. So Pub backup to Pub restore (same version etc.) & Sub backup to Sub restore (same version etc.) This is explained quite nicely here;
http://cisco.biz/en/US/docs/voice_ip_comm/cucm/drs/7_0_1/DRS_CUCM/drsag701.html
Cheers!
Rob
mazenelhourani Wed, 08/18/2010 - 11:37
Alright alright I misunderstood a previous post because that's the info I already know
Thanks for all the help Rob.
