08-13-2010 08:26 AM - edited 03-16-2019 12:14 AM
I´m having problems sending the cdr records to a ftp server.
The 2821 is running c2800nm-spservicesk9-mz.124-24.T1.bin and cme 7.1.
The symptom are those described in the CSCtb72550 caveat.
The release notes for the last IOS said "Workaround: Downgrade to a version of Cisco IOS software that does not contain the fix for CSCta23301 or push the CDR records locally to flash instead of to an FTP URL".
I would like to know if this issue is resolved (or not) in the last ios.
Thanks.
Solved! Go to Solution.
08-13-2010 11:41 AM
Hi Rafael,
Here are the "Fixed-In" versions
Fixed-In
12.2(52)SE
15.0(1)M
12.4(20)T4
12.4(24.6)PI11p
12.4(24)YG
12.2(32.8.11)XJC273.8
12.4(24.6.5)PIB12
12.2(32.8.11)YST273.3.3
12.4(22)T3
15.1(24.6.8)PIL12
12.4(15)T10
12.2(32.8.11)SX297
12.4(24)MD
12.4(24.6)M0.1
15.1(24.6.3)PIL13
12.4(24)T2
12.2(32.8.1)YCA273.15
12.4(25b)M0.5
12.4(22)YE2
15.1(1)XB
12.4(24)YE
15.1(1.5.1)PIA13
15.1(1.7.1)PIA14
12.2(32.8.15)YCA273.10
12.2(33)SXI4
12.4(24)GC2
12.4(22)MDA4
12.4(24)MDA1
Cheers!
Rob
09-01-2010 12:33 PM
Hi Rafael,
Try Tools & Resources > Software Downloads
Cheers!
Rob
08-13-2010 11:41 AM
Hi Rafael,
Fixed-In
12.2(52)SE
15.0(1)M
12.4(20)T4
12.4(24.6)PI11p
12.4(24)YG
12.4(24.6.5)PIB12
12.4(22)T3
15.1(24.6.8)PIL12
12.4(15)T10
12.2(32.8.11)SX297
12.4(24)MD
12.4(24.6)M0.1
15.1(24.6.3)PIL13
12.4(24)T2
12.4(25b)M0.5
12.4(22)YE2
15.1(1)XB
12.4(24)YE
15.1(1.5.1)PIA13
15.1(1.7.1)PIA14
12.2(33)SXI4
12.4(24)GC2
12.4(22)MDA4
12.4(24)MDA1
Cheers!
Rob
09-01-2010 12:08 PM
Hi Rob, where can I get one of following:
12.4(20)T4
12.4(22)T3
I do not see those files on the cisco page:
09-01-2010 12:33 PM
Hi Rafael,
Cheers!
Rob
09-05-2010 09:33 PM
finally it works with the c2800nm-spservicesk9-mz.124-24.T3.bin.
but the gw-accounting file comand has a trick!.
1. you must define the ip of the ftp server with the ip host ftpserver xxx.xxx.xxx.xxx command
2. use the primary ftp command with the host defined with the ip host command.
3. for some reason I had to append an "/" to the name defined with the ip host ... in the primary ftp command.
4. using the ip address instead of the ftp server name do not work.
Example:
ip host ftpserver 10.10.10.10
gw-accounting file
primary ftp ftpserver/ username test password test
