Jagdeep Gambhir Fri, 08/13/2010 - 10:13
  • Red, 2250 points or more
CSCsr56625            Bug Details
Telnet service is available once after getting a DHCP  address
Symptom:
When the 1113 appliance is running  4.2.0.124, configured for dhcp, and attached to network after  fully-started, the telnet port is open on appliance even with CSA  running.  The telnet port will remain open until someone exit a telnet  session from the appliance.
The telnet port will also open if the  ethernet port goes down/up.  It will also reopen it the appliance is  configured to use DHCP.
Conditions:
Workaround:
Apply   a ACL on the L3 interface to block port 23 to ACS
Re-image appliance with 4.2.0.124 and upgrade to 4.2.1 build 11.
Unplug the Ethernet cable from appliance.
Reboot the appliance via CLI.
Plug the Ethernet cable to appliance when appliance came up.
Do telnet into appliance.
Expected / Observed behavior:
You should not be able to telnet into the appliance after connecting the cable
[Wrap  text]  [Edit this enclosure]
V-comments: Added 09/08/2009 05:50:38  by sarmohan
[Unwrap  text]  [Edit this enclosure]
Unit-test: Modified 11/09/2008  20:25:55 by rsivaji
Static-analysis: Added 11/09/2008  20:24:19 by rsivaji
Code-review: Added 11/09/2008  20:23:59 by rsivaji
R-comments: Added 11/09/2008 20:20:43  by rsivaji
The issue has been resolved by filtering the packet for right IP address.
SS-Review: Modified 10/31/2008  07:25:22 by jefkelle
$$NOOIB
Release-note: Modified 08/17/2008  14:03:31 by daladen
Symptom:
Conditions:
Workaround:
Further Problem Description:
Steps to Recreate: Added 07/24/2008  12:48:05 by daladen
[Uwrap  text]  [Edit this enclosure]
Diff_Report_Nov_06_2008_1205: Added  11/05/2008 22:36:08 by px-build
Can not view this .html file attachment inline, please click on the following link to view the attachment.
http://cdetsweb-prd.cisco.com/apps/dumpcr_att?identifier=CSCsr56625&title=Diff_Report_Nov_06_2008_1205&ext=html&type=FILE
http://
[UnWrap  text]  [Edit this enclosure]
[Wrap  Text]  [Edit this enclosure]
~JG
amardram123 Fri, 08/13/2010 - 10:31
thanks for the info..
Is there any way to kill the telnet session and disable the telnet service manually.
amar
amardram123 Tue, 08/17/2010 - 03:43
ACS SE v4.2.1 build 11 is not available on Cisco Site, Can i upgrade the appliance to ACS SE v4.2.1 build 15.
Please some1 confirm is i can upgrade from 4.2.0 build to 124 to 4.2.1 build 15 using the below file.
http://tools.cisco.com/support/downloads/go/ImageList.x?relVer=4.2.1.15&mdfid=281458154&sftType=Secure+Access+Control+Server+%28ACS%29+Solution+Engine&optPlat=&nodecount=7&edesignator=null&modelName=Cisco+Secure+Access+Control+Server+Solution+Engine+4.2&treeMdfId=268438162&modifmdfid=null&imname=&treeName=Security&hybrid=null&imst=null
ACSse-Upgrade-Pkg-acs-v4.2.1.15-K9.zip
Release Date: 26/Nov/2009
Upgrade Package for ACS SE v4.2.1.15 (ACS Software package)
Size: 48190.17 KB  (49346725 bytes)
Amar
cristian.munoz Fri, 12/09/2011 - 12:33
Hi Amar
The ACS SE have version Release 4.2(0) Build 124
Regards.
Cristian
