SCE 8000 Bittorrent Classification Problem
Aug 13th, 2010
Hi!
I have SCE 8000 and try to limit bandwith for test user.
My user has test Package with
- Primary BWC UP/DOWN CIR 0 kbps PIR 2048 kbps,
- Default BWC UP/DOWN CIR 0 kbps PIR 2048 kbps,
- Bittorent BWC UP/DOWN  CIR 0 kbps PIR 256 kbps,
- Download over HTTP UP/DOWN  CIR 0 kbps PIR 512 kbps.
SCE generate Real-Time Subscriber Usage RDR for test user.
There are two problems:
- average bandwith of bittorrent is ~ 320 kbps, max up to 440 kbps, not 256 kbps
- there are peers (uTorrent 2.2, uTorrent 2.0.2) traffic from which is not classify as Bittorrent. In report I saw "Other UDP"
Did you ever resolve this?
SCE SW version: 3.6.0, Protocol Pack 22 Build 19
lamersons Tue, 08/31/2010 - 23:44
Pretty much the same problem here. Same version(3.6) and same PP(22) only sce2000.
What im trying to do is to cut p2p from a service. If a torrent client is set to full encryption + random ports, sce starts to classify it as other tpc/udp,default service and so on. Once in a while it will cut download speed to zero, but then again some new peers whould do the job. Basicly it just takes longer to download a torrent file and it ruines the whole meaning of blocking p2p. Also i've tryed to limit bandwith to 1kbps - doesnt work.
So i'm joining your thread in a search for some kind of work around to this problem.
Thank you in advance.
Jaime Soto Vale... Tue, 09/28/2010 - 14:46
I have the same problem with Bittorent classification in a SCE 2020 (version 3.5.5 and PP22).
Did you find any solution on this?
Jaime.
