How to view the Syslog Application logs in CLI
On CallManager 6.1.x, how do we view the Application Logs in the Syslog Viewer using the CLI?  I know how to view the traces but not the Application or System logs in CLI.  My RTMT to a customer is being blocked so I need to use the CLI.  Thanks.
htluo
Level 9
Level 9
Event Viewer-Application Log = /var/log/active/syslog/CiscoSyslog.*
Event Viewer-System Log = /var/log/active/syslog/messages.*
From CLI:
To list application logs:
file list activelog syslog/CiscoSyslog.* date detail
To list system logs:
file list activelog syslog/messages.* date detail
To view a specific application log:
file view activelog syslog/CiscoSyslog.1
To view a specific system log:
file view activelog syslog/messages.1
http://htluo.blogspot.com
Michael
7 Replies 7
Jaime Valencia
You can't you forcefully need RTMT for that
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
htluo
Level 9
Level 9
From CLI:
Michael
I had no idea you could get those via CLI, I'll have to save those commands
java
java
Great, thanks Michael.  Is there a way that you can do a search for a keyword in the logs without having to look through the entire log?
   Tony
file search activelog syslog/CiscoSyslog.* my-keyword
Michael
Hi  i have this error:someone have the answer?
a linsencing error occured, if the try again in five minutes; if the problem persist, please please see your log file or system administrator
old thread revival alert; sorry
this has been super helpful, thank you
i am wondering though if there is a way you can view the file without doing the n=next p=prev steps, so does a dump of all to screen?
