CUCM Corporate Directory DB Read Access
Aug 13th, 2010
CUCM 7.x, NO AD integration. Client wants to read from the Corporate Directory and publish to a web site.
Alternately, can we use an anonymouse login or setup auto-logic to link to the UCM-published directory?
Thanks in advance,
Brian
Aaron Harrison Fri, 08/13/2010 - 11:43
  • Community Spotlight Award,
    Member's Choice, May 2015
Hi Brian
A couple of options spring to mind:
1) Screen scrape the directory web service - you could submit queries to the directory URL used by the IP Phones (sniff their traffic to see how they search) and then parse the results
2) Use AXL to submit a SQL request 'select * from enduser' to the CCM; this will return an XML formatted result set that your developers can then work with. The 'AXLSqlToolkit' is available from the Plugins download page on CCMAdmin; this is an example of how to do AXL SQL queries using Java that your developers can start with...
Aaron
Please rate helpful posts...
