Error Adding HA Second Node UCCX 7.01(SR5)
Aaron Harrison Fri, 08/13/2010 - 11:36
Are you adding the server with the local Windows administrator/password or an application administrator? It should be the application user (i.e. a user from CCM End Users with CRS Administrator rights).
Have you built both servers with the same local administrator account password?
Aaron
Running the configuration wizard and when it asks for the CLuster Publisher Server IP and Username and password, I am
using the CCM user that was chosen when the primary was configured.
Same local Administrator password for both servers. Also one thing to note is that a secondary server was in the CLuster and we had to replace it with new hardware. Both Hardware platforms are the same.
joesnyde Mon, 08/16/2010 - 05:28
This is an issue with mismatched passwords between both nodes. Use the CCX Admin Utility to change the CRSAdministrator account password on node2 to match node1.  Add to Cluster should now proceed without the error message.
Joe
