2960G Clustering Configuration
Aug 13th, 2010
Here's my scenario:
I have three WS-C2960G-24TC-L which need to be "connected to each other" and located in the same rack.
Every Switch has one GLC-LH-SM Transceiver on one of its SFP ports.
What is the best way to cluster them? (See attached image).
Will I be able to manage, operate and configure them as a single Switch?
Thanks in advance.
Reza Sharifi Fri, 08/13/2010 - 13:16
  • Cisco Designated VIP,
    2017 LAN
Hi Raul,
Yes, you can mange the cluster using a single IP address
From the config guide:
A switch cluster is a set of up to 16 connected, cluster-capable Catalyst switches that are managed as a single entity. The switches in the cluster use the switch clustering technology so that you can configure and troubleshoot a group of different Catalyst desktop switch platforms through a single IP address.
Also for the best way of clustering you switches together refer to this document
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_fx/configuration/guide/swclus.html
Reza
Raul Armas Tue, 10/05/2010 - 15:23
I know this question is supposed to be already answered but:
Does this means the two switches will be working exactly as one?
I don't mean just managing them with a single IP address. I need to be absolutely sure.
Thanks.
