Send WIPS Events to a Syslog Server
Aug 13th, 2010
   Today I have a WIPS Server which send SNMP Traps to a WCS and I can see the alarms generated by the WIPS in WCS...
   Is there any way for me to send the events or alarms created by WIPS to a Syslog Server ???
   Andre Lomonaco
Stephen Rodriguez Fri, 08/13/2010 - 12:42
Currently the Syslog implementation on the WLC is not granular enough to be able to specify what error are going to be sent.  We only have a
generalized mechanizm to adjust the level.  You could find the levle of Syslog that WIPS will send, but you will also receive all the other messages at that level.
lomonaco Fri, 08/13/2010 - 13:33
Hi Stephen,
  I forgot to say in my Question that I'm using WIPS from a MSE Server, not the WIPS avaliable in the WLC....
  Really, I disable the IPS in Controllers and I'm using only the MSE Service with WIPS Service installed
Trending Topics - Security & Network
