Can't ping isp DNS or Internet
Answered Question
Aug 13th, 2010
For some reason I can't ping the dns or browse to the Internet.
I have a cisco 851W
I have DSL and setup to dhcp.
When I do a show ip int 4 it shows a ip address picked up for my ISP. So  I know I can get a IP address but I can't ping the DNS which is
72.235.80.12 and 72.235.80.4
Thanks.
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname smithrouter
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 cisco
no aaa new-model
dot11 syslog
dot11 ssid tgsmdinc
authentication open
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp pool ccp-pool1
import all
network 192.168.1.0 255.255.255.0
dns-server 72.235.80.12 72.235.80.4
default-router 192.168.1.1
ip cef
no ip bootp server
ip domain name smith.local
ip name-server 72.235.80.12
ip name-server 72.235.80.4
username smith privilege 15 secret 5 cisco
archive
log config
hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Dot11Radio0
no ip address
ssid tgsmdinc
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip nat inside
ip tcp adjust-mss 1412
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Correct Answer by Nagaraja Thanthry about 6 years 9 months ago
Hello Tony,
Can you remove the default route you have in the configuration?
no ip route 0.0.0.0 0.0.0.0 FastEthernet4
Then, bounce the FastEthernet 4 interface. That should allow the ISP to set
the default route.
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
kyukim Fri, 08/13/2010 - 15:06
  • Cisco Employee,
Hi, Tony.
If you can't ping your ISP DNS but you can ping ISP default GW, this means your ISP DNS has a problem.
I do see this kind of problem from my ISP too.
Try to use public well known DNS server, like 4.2.2.2.
I usually configure my dhcp server to use one of my ISP dns and secondary as 4.2.2.2
ip name-server 4.2.2.2.
Try to ping 4.2.2.2 from your router. If you can't ping, then your ISP has a problem.
KK
tonymlee18 Fri, 08/13/2010 - 15:27
Hi KK
I still can't get out to the Internet.
If I use my other router I can ping both DNS and go to the Internet fine.
I just have this problem with the cisco router.
Any other suggestions?
thanks
btw cant ping 4.2.2.2 either but I can ping the gateway fine.
if i'm on my linksys router I can ping 4.2.2.2 and 72.235.80.12 just fine but not on the cisco router.
Correct Answer
Nagaraja Thanthry Fri, 08/13/2010 - 15:47
  • Cisco Employee,
Hello Tony,
the default route.
Hope this helps.
NT
