How to setup g729 for SPA phones
Answered Question
How can I setup SPA extensions to use g729 CODEC?
Correct Answer by David Hornstein about 6 years 9 months ago
Hi David,
I am answering your question reluctantly as I am trying to figure why to want to run G729 between IP phones.
But here is an example i just manually altered on my UC520 using CLI.
I manually  altered my ephone 6,  which is a SPA504G phone,  only as a example for my UC520.
But, my concern is  if you start to make changes to CLI, i do hope you don't loose the ability for Cisco configuration Assistant (CCA) to  manage your UC540 or UC560.  I do hope you have the skills to make changes and save changes.
As you may or may not appreciate,  the Small Business Support Center (SBSC), who manage UC540 and UC560 cases,  prefer to diagnose issues and make changes to UC540 or UC560 via CCA and not CLI.
Altering values that are normally set by CCA  could be bad if you are a newbee to UC5XX.
Please check the implications of the changes with the most current 'out of band'  configuration guide that can be searched for in this community site.
ephone  6
device-security-mode none
mac-address 0028.B8FF.D514
ephone-template 16
max-calls-per-button 2
username "dan" password xxxxxx
paging-dn 1
codec g729r8 dspfarm-assist
type 504G
button  1:11
UC520#show ephone 504g
ephone-6[5] Mac:0018.B9FF.D514 TCP socket:[8] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 8/8 max_streams=1 SPCP ver 1/1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:12
IP:10.1.1.20 * 1026 SPA504G  keepalive 18 max_line 4 available_line 4
button 1: cw:1 ccw:(0 0)
  dn 11 number 202 CH1   IDLE         CH2   IDLE
paging-dn 1
Preferred Codec: g729
Lpcor Type: none Username: dan Password: xxxxxx
I made a call to a 7965  and here is the stream statistics screen capture taken from the 7965 IP phone.
Overall Rating: 5 (1 ratings)
Correct Answer
David Hornstein Fri, 08/13/2010 - 21:23
  • Gold, 750 points or more
Hi David,
ephone  6
ephone-template 16
paging-dn 1
type 504G
button  1:11
paging-dn 1
