Bandwidth Management in WRVS4400N
Aug 13th, 2010
I need help setting up Rate Control in Bandwidth Management. It doesn't seem to work at all. I knew from some other Posts that I need to have IPS on and I do.. Is there something else I need to do.
My users are connected wirelessly to the router through three different SSIDs  and I have 3 VLANS. I need to set some limitations on two of the LANS.
Please help me find a way to get this to work..
bogdan.grigorov... Thu, 01/17/2013 - 04:10
We had the same problem. Rate Control didn't seem to work.
I discovered that after changing the rate control settings and saving these settings the router needs a reboot.
Otherwise the rate control does not work anymore and the bandwidth is not managed.
Whenever something is modified in the rate control settings you have to reboot the router.
Related Content
