u1kumar2002 Sat, 08/14/2010 - 00:24
   Acl is used for filtering the traffic based on configured parameters. But it is a single statement. If it match then it will permitted or denied. But you get more flexibility in Route-maps. You can use the ACL as a match statement in Route map and same time you can set some attributes which will get attached to that prefix and it will be advertised in WAN with same to achieve some routing requirement.
As per my understanding its Route-map give me full flexiblity to route my traffic from where i want like interface, attach attribute, etc. Its a kind of programming i can see. Like for this match do this ...
Route-map are used in redistribution, BGP neighborship, etc
For more detailed information visit: http://startnetworks.blogspot.com/2010/08/cisco-acl-and-route-map.html
Hope this information will help you....
Uttam
http://www.startnetworks.blogspot.com/
raymk1973 Fri, 05/24/2013 - 06:34
am currently experiencing and issue with a route map.
i believe the route-map to be configured correctly but the route map does not appear to be matching the acl
GigabitEthernet0/0 is up, line protocol is up
  Internet address is 172.20.38.254/16
interface GigabitEthernet0/0
ip address 172.20.38.254 255.255.0.0
ip route-cache flow
ip policy route-map EXC-DAG
route-map assigned to interface
show ip int gi0/0
Policy routing is enabled, using route map EXC-DAG
route-map EXC-DAG, permit, sequence 20
  Match clauses:
    ip address (access-lists): 150
  Set clauses:
    ip next-hop 172.20.57.234
  Policy routing matches: 0 packets, 0 bytes
access-list 150 permit ip 192.168.4.0 0.0.0.255 192.168.3.0 0.0.0.255
show access-list 150
10 permit ip 192.168.4.0 0.0.0.255 192.168.3.0 0.0.0.255 log (3 matches)
show route-map
  Match clauses:
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes <<<<
i dont think i am missing anything from the configuration
any ideas?
thanks in adviance.
paul driver Fri, 05/24/2013 - 06:54
  • Red, 2250 points or more
You can policy route via the data plane ( that is traffic traversing your router) or Control plane( traffic originating from the router) by specifying acls, protocol types and port numbers
For Data plane PBR you specify the policy on the interface from where the traffic is travesing from -
int xx
ip policy route-map TST
For Control plane you specify the policy globally on the router the traffic originates from -
conf t
ip local policy route-map TST
In your policy you are using acl 150 to specify traffic originating from  interface gig0/0 between
192.168.4.0 0.0.0.255 192.168.3.0 0.0.0.255 to be routed out of the next hop interface of
172.20.57.234 -
Is this what you want to happen?
Also you have no resiliency set in place, so if the next hop  interface is unreachable your present policy will still try to forward  traffic based on the match statements and start arping for the next hop  address.
apply set ip next-hp verify-availability into  the policy so in this way the router will do a cdp lookup for the  next-hop address before policy routing and if not found will instead  route normal.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Sindhu_kumar Fri, 05/24/2013 - 07:03
Can you disable CEF and check
Also in the ACL you have use log keyword can you remove that and check.
Do not use the "log" key word on ACLs when using PBR.  Here is a note from Cisco.
"The log keyword should not be used with this command in policy-based routing (PBR) because logging is not supported at the interrupt level for ACLs."
Richard Burts Fri, 05/24/2013 - 11:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I believe that there is a simple logic problem here that is causing PBR to not work as desired.
First notice the subnet configured on the interface where PBR is configured
Then notice the source address specified in the ACL used with PBR
So my question is whether 192.168.4.0 is really connected through interface Gig0/0? That is the only way that PBR configured like this will work.
Rick
raymk1973 Tue, 05/28/2013 - 04:05
And thanks for the speedy responses, your input has been very helpful.
i have since been able to  get it to work this morning.
the device connected on this interface Gi0/0  is a firewall that had a missing routing entry.
added the following static route 192.168.3.0 255.255.255.0   use    172.20.38.254   255.255.255.0
192.168.3.0     172.20.38.254   255.255.255.0   UG
  Match clauses:
  Set clauses:
  Policy routing matches: 3075964 packets, 555386572 bytes
Thanks to you all for you imput, Apprecitated.
raymk1973 Tue, 05/28/2013 - 04:06
Paul,
cant seem to rate your post. shame as it was very informative!
thanks
ray
