how to remove the mgcpapp service and pots dial peer from fxo port.
Aug 14th, 2010
Under this dial peer 1023 Mgcpapp services are running on the fxo port 0/2/3, I would like to remove MGCPAPP services as well as the dial peer 1023 .
Configuration as below :
dial-peer voice 1023 pots
service mgcpapp
port 0/2/3
For example if I want to deletes the POTS dial-peer 1023 it will be deleted the Service mgcpapp automatically from the dial-peer or we need to deleted the mgcpapp service separetely .
no dial-peer voice 1023 pots
This command will delete only this the dial-peer 1023 as well as the service mgcpapp. or else intentional we need to delete service mgcpapp form this dial-peer 1023 port .by the command
no service mgcpapp
port 0/2/3
Tomas De Leon Mon, 08/16/2010 - 14:21
Syed,
This is the incorrect forum for this question.
You need the Voice\Voip forum, but I will try to assist
you.
If I understand you question, you are trying to remove the
"dial peer 1023"
Try Removing the following in sequence:
* delete the port
* delete the Pots dial-peer
* save running-config
* reboot gateway
Note:  If this is a production gateway, only due this during a scheduled outage window.
I hope this helps
T.
