Aug 14th, 2010
Dear All,
I using VPN concentrator for remote access VPN and ASA 5520 for Site to site VPN tunnel, remote access and AnyConnect VPN.
I need to scrap the VPN concentrator and use the outside interface  IP address of the VPN concetrator to the ASA without distrubing the ASA outside interface setup. Will it be possible to use the VPN load balancing in ASA ??
Idea are welcome!
Thanks in advance
Balajirajah P B
Paul Carco Sat, 08/14/2010 - 10:53
Are you saying you are now going to have an ASA load-balanced cluster when you scrap the "concentrator" (vpn3k??) ?
If the VPN Concentrator's Public Intf is on the same network as the ASA's Outside Intf then I dont see any issue with using the VPN Concentrators Public IP as the Cluster IP address on the ASA..   Devices that terminate to the IP assigned to the physical interface should still be reachable - they are on my LB Clusters.
Best regards,
