Architecture IP Telephony with MCS-7825
Aug 14th, 2010
Hello
I would like to know whether an architecture for ip telephony with servers 7825 for 915 users is possible and also valid technically, i am calculating a clustering over IP WAN deployment, two servers (publisher and subscriber) on one site and two servers (subscribers) on other site applying balance of users between sites.
Is it possible????
Thanks a lot.
Alexis Munoz
Jaime Valencia Sat, 08/14/2010 - 12:30
Yes, refer to the SRND deployment models chapter for clustering over the WAN requirements and call processing chapter for platform capacities.
Unified CM Capacity Planning
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/callpros.html#wp1156290
If you're not using 8.x refer to the applicable SRND for your version, same chapters.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
