How to register Polycom Phone to CallManager
Aug 14th, 2010
Would someone tell me how to register the Polycom SoundStation IP 5000 Phone on CallManager 7? Should it be configured as an H.323 Phone or a Sip(Basic)device. The callmanager is integrated to AD. Any document available?
Madhu
William Bell Sat, 08/14/2010 - 20:01
  • Purple, 4500 points or more
If you have SIP stack on phone then I would go with SIP. Create it as a
basic SIP device CUCM. It is really quite simple. Here is a polycom doc on
configuring the phone itself:
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBwQFjAA&url=http%3A...
2Fknowledgebase.polycom.com%2Fknowledgebase%2FEnd%2520User%2FTech%2520Alerts
%2FAudio%2FRegister_Standalone_SoundPointIP_SoundStationIP_QT44011.pdf&ei=Vl
dnTISCMcL78Ab-sMyzBA&usg=AFQjCNGMBcjbJyq9ENmB-ar8A1TXOS3ZVQ&sig2=k0Zbl5aUrPq
WWCNYzo80Pw
AD integration will make no difference.
HTH.
Bill
brendand05 Sun, 08/15/2010 - 23:21
If the polycom supports H.323 add it as a H.323 device
If the polycom supports SIP add it as a SIP device.
