How to configure dial-peer redundancy
Hello all,
i am configuring a voip dial-peer and i have two servers which will be the session target but while i am putting the configuration its not allowing me to give two IPV4 Targets , so how i can give both of them in the config?
dial-peer voice 139 voip
description ****test dial-peer****
service session
destination-pattern 8390
voice-class codec 1
session protocol sipv2
session target ipv4:10.10.11.235
session target ipv4:10.10.11.233 ***Suppose to be secondary
incoming called-number 8390
dtmf-relay h245-signal h245-alphanumeric rtp-nte
no vad
nascoentr
create two dial-peers with the same destination pattern and add the prefernce command to the dial-peer, the lower the preference the higher the priority
ex:
dial-peer voice 1 voip
destination-target 1...
preference 1
session-tartget ipv4: 192.168.1.1
dial-peer voice 2 voip
preference 2
session-target ipv4: 192..168.1.2
here, dial-peer 1 will be used first and then dial-peer 2 as a failover/redundancy
5 Replies 5
nascoentr
ex:
preference 1
preference 2
I chaked
the same and its working
thanks.
mind rating my reply, thanks
how is it now
great thanx.
