How to delete the mgcpapp service from FXO ports under the dial-peer.
Answered Question
Aug 15th, 2010
Hello
Configuration as below :
dial-peer voice 1023 pots
service mgcpapp
port 0/2/3
According to the above configuration if I WANT TO delete a defined dial peer by using
# no dial-peer voice 1023 pots
It will also deleted the services and port 0/2/3 which are running under this dial-peer without any effect to other dial peer configuration at gateway. or else its enough this command to delete  the dial peer along .
Thanks i advance .
Correct Answer by Steven Holl about 6 years 8 months ago
'no dial-peer voice 1023 pots' will remove the entire dial-peer, and all of it's sub-configuration.
If you just need to remove the 'service mgcpapp' config, 'default service' should do that.
-Steve
Overall Rating: 5 (1 ratings)
Correct Answer
Steven Holl Tue, 08/17/2010 - 08:12
  • Cisco Employee,
-Steve
Syed Akbar Ali Thu, 09/16/2010 - 15:09
Hi Steven
Thanks for your helpful information.
I have one more question to clear . Presently iam working at CCM 5.0 with Administration Account . I would like to create CCM new account for new
trainee engineer with limited access i.e Standard CCM Phone Administration and Management only . like adding new  ip Phone change the existing user name and extension only
So please advice how to create an new CCM Account with the above limited Access.
Highly apprecited for your quick response .
