Cisco 3845 cannot detect HWIC-4B-S/T
Answered Question
Aug 15th, 2010
I have just received a Cisco 3845 and I have installed 2 ISDN BRI cards HWIC-4B-S/T. The router has only these cards and a AIM VPN module installed.
The router cannot detect the cards.
I have placed an isdn BRI card  HWIC-S/T ( 1 port ) it detects it without any problem on the same slot HWIC 0 and then HWIC 1 to test if the slots are ok too.
My question is there a problem on the HWIC-4B-S/T cards or any configuration to make.
The documentation says the router 3845 supports the HWIC-4B-S/T cards.
Please advise,
Thanks for your support,
Ashley Dewoo
Correct Answer by Giuseppe Larosa about 6 years 8 months ago
Hello Ashley,
datasheet is here:
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/data_sheet_c78_439536.html
it says:
Supported in NM-1FE2W-V2, NM-1FE1R2W, NM-2FE2W-V2, and NM-2W
Can not be inserted into a mixed-media network module
post sh inventory
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
ashley_dew Sun, 08/15/2010 - 23:31
I found the solution,
You need to upgrade to IOS Advanced Services 12.4(20) T for the router to detect the cards.
For some reasons, the ios advanced security 12.4 (23) which i had previously did not support these cards.
Thanks again,
Ashley
