ACE session persitence "sticky" TCP port
ppalmerjr
Hey guys,
I trying to work up some configurations on the ACE for performing session persistence "sticky" on the ACE based on source TCP port.  All flows are SSL based therefor, I thought the only option was SSL-ID but I've been running into querky behavior due to clients using IE7.  Evidently there are several cases where IE7 causes the SSL-ID to be regenereated causing this weird behavior.
Anybody have example configs of the layer4-payload offset, length, etc. to perform sticky based on TCP source port?
Thanks in advance.
Paul
litrenta
Level 3
Level 3
Since source port is not part of the layer 4 payload you cannot  use it for sticky. IE changing ssl id is a known problem (does it every 2 minutes).
So you are left with:
terminating SSL on the ace and using cookie sticky (you can always re-encrypt on back end if security demands it)
or
source IP sticky (practical only if clients are not behind a proxy  device)
