Cisco IPS4255 won't boot (error=Searching / for images to boot. No images found in / Error 15: File not found unable to boot an image)
Answered Question
Aug 15th, 2010
I have a Cisco IPS4255 that will not boot an image.  I'm seemingly successfully completing a TFTPDNLD each time, but it keeps rebooting with the cannot find image in \ error.
Here is a detailed snap shot:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
#1- I TFTP image to device which automatically starts the output below:
ENABLING IO-APIC IRQs
Setting 14 in the phys_id_present_map
...changing IO-APIC physical APIC ID to 14 ... ok.
Setting 13 in the phys_id_present_map
...changing IO-APIC physical APIC ID to 13 ... ok.
..TIMER: vector=0x31 pin1=2 pin2=0
testing the IO APIC.......................
.................................... done.
Using local APIC timer interrupts.
calibrating APIC timer ...
..... CPU clock speed is 3000.1599 MHz.
..... host bus clock speed is 200.0105 MHz.
cpu: 0, clocks: 2000105, slice: 1000052
CPU0<T0:2000096,T1:1000032,D:12,S:1000052,C:2000105>
Waiting on wait_init_idle (map = 0x0)
All processors have done init_idle
PCI: PCI BIOS revision 2.10 entry at 0xff648, last bus=4
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
PCI: Ignoring BAR0-3 of IDE controller 00:1f.2
Transparent bridge - Intel Corp. 82801BA/CA/DB/EB PCI Bridge
PCI->APIC IRQ transform: (B0,I29,P0) -> 16
PCI->APIC IRQ transform: (B0,I29,P1) -> 19
PCI->APIC IRQ transform: (B0,I29,P3) -> 23
PCI->APIC IRQ transform: (B0,I31,P0) -> 16
PCI->APIC IRQ transform: (B0,I31,P1) -> 17
PCI->APIC IRQ transform: (B2,I1,P0) -> 18
PCI->APIC IRQ transform: (B3,I1,P0) -> 24
PCI->APIC IRQ transform: (B3,I2,P0) -> 24
PCI->APIC IRQ transform: (B3,I2,P1) -> 25
PCI->APIC IRQ transform: (B3,I3,P0) -> 26
PCI->APIC IRQ transform: (B3,I3,P1) -> 27
PCI->APIC IRQ transform: (B4,I2,P0) -> 16
PCI->APIC IRQ transform: (B4,I3,P0) -> 17
PCI: Cannot allocate resource region 0 of device 00:00.0
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
allocated 32 pages and 32 bhs reserved for the highmem bounces
Journalled Block Device driver loaded
keyboard: controller not found
pty: 2048 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS MULTIPORT SHARE_IRQ SER
IAL_PCI ISAPNP enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
Real Time Clock Driver v1.10f
RAMDISK driver initialized: 16 RAM disks of 30720K size 1024 blocksize
loop: loaded (max 8 devices)
lpc: version 0.1 (Mar  4 2005)
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
hda: TOQHIBA THLCD512MBA, CFA DISK drive
hdb: QalDisi QDAF@-510, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: attached ide-disk driver.
hda: task_no_data_intr: status=0x51 { DriveReady SeekComplete Error }
hda: task_no_data_intr: error=0x04 { DriveStatusError }
hda: 484848 sectors (248 MB) w/2KiB Cache, CHS=481/16/63
hdb: attached ide-disk driver.
hdb: task_no_data_intr: status=0x51 { DriveReady SeekComplete Error }
hdb: task_no_data_intr: error=0x04 { DriveStatusError }
hdb: 484848 sectors (248 MB) w/1KiB Cache, CHS=481/16/63
Partition check:
hda: hda1 hda2 hda3 hda4
hdb: hdb1 hdb2 hdb3 hdb4
ide: late registration of driver.
SCSI subsystem driver Revision: 1.00
i2c-core.o: i2c core module version 2.8.7 (20040611)
i2c-dev.o: i2c /dev entries driver module version 2.8.7 (20040611)
i2c-proc.o version 2.8.7 (20040611)
i2c-i801 version 2.8.7 (20040611)
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 32768 buckets, 256Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 26522k freed
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 136k freed
init started:  EXT2-fs warning: checktime reached, running e2fsck is recommended
BusyBox v1.00-rc1 (2005.03.04-09:39+0000) multi-call binary
init started:  BusyBox v1.00-rc1 (2005.03.04-09:39+0000) multi-call binary
Starting pid 10, console /dev/ttyS0: '/etc/init.d/rcS'
Recovery version 1.13
Started on Sun Mar  7 05:17:41 UTC 2010
Full system recovery
A
Please press Enter to activate this console.
tarting pid 86, console /dev/ttyS0: '/bin/sh'
BusyBox v1.00-rc1 (2005.03.04-09:39+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
#2- I’m not a unix/linux person so I don’t have the knowledge to fix the “hdx” errors above, so after reboot it goes to “rommon”
Booting system, please wait...
CISCO SYSTEMS
Embedded BIOS Version 1.0(10)0 03/25/05 22:42:05.25
Low Memory: 631 KB
High Memory: 3968 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  00  00   8086   2578  Host Bridge
00  01  00   8086   2579  PCI-to-PCI Bridge
00  03  00   8086   257B  PCI-to-PCI Bridge
00  1C  00   8086   25AE  PCI-to-PCI Bridge
00  1D  00   8086   25A9  Serial Bus         11
00  1D  01   8086   25AA  Serial Bus         10
00  1D  04   8086   25AB  System
00  1D  05   8086   25AC  IRQ Controller
00  1D  07   8086   25AD  Serial Bus         9
00  1E  00   8086   244E  PCI-to-PCI Bridge
00  1F  00   8086   25A1  ISA Bridge
00  1F  02   8086   25A3  IDE Controller     11
00  1F  03   8086   25A4  Serial Bus         5
00  1F  05   8086   25A6  Audio              5
02  01  00   8086   1075  Ethernet           11
03  01  00   177D   0003  Encrypt/Decrypt    9
03  02  00   8086   1079  Ethernet           9
03  02  01   8086   1079  Ethernet           9
03  03  00   8086   1079  Ethernet           9
03  03  01   8086   1079  Ethernet           9
04  02  00   8086   1209  Ethernet           11
04  03  00   8086   1209  Ethernet           5
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(10)0) #0: Fri Mar 25 23:02:10 PST 2005
Platform IPS-4255-K9
Management0/0
Link is UP
MAC Address: 000f.f775.7e24
Use ? for help.
rommon #0>
#3- If the TFTP is rerun the entire cycle starts again.
Correct Answer by Dustin Ralich about 6 years 6 months ago
The IPS 4255 sensor appliance has only a single 512 MB internal CompactFlash module for storage by-default, so this part of the output you posted is interesting:
As it appears that two (2) 256 MB ("248 MB") storage devices are being detected (despite the model of the first even containing "512MB" in its name).
I'd recommend double-checking that there is nothing installed in the "External compact flash device" slot located on the back of the appliance. See here for reference: http://www.cisco.com/en/US/docs/security/ips/7.0/installation/guide/hw_installing_4240_4255.html#wp2726
If there is a CompactFlash module installed there, eject and remove it, then power-cycle the appliance and attempt the re-image ("recovery") process once more. If the boot output still contains the same errors for hda and hdb, then it is probably a failing/failed CompactFlash module, so an RMA will likely be necessary to resolve.
Overall Rating: 5 (1 ratings)
Correct Answer
Dustin Ralich Mon, 08/23/2010 - 07:05
fjatkinson Mon, 08/23/2010 - 15:45
Your feedback helped 125%.  The problem turned out to be 2-fold.  I did have an external flash card installed.  Once I removed that as per your direction, the TFTP'd image finally booted.  However when I rebooted, it would go back to rommon.  If I booted from roomon, it woudl go back to sensor prompt..back-n-forth.  I then realized that I must have messed around with the config-register.  After updating the register, I no boot to "sensor#" prompt every time.
Again, thanks for you timely and 100% effective feedback.
