Multi-site (MPLS) call transfer caller ID on PSTN (sip) calls
Answered Question
Aug 15th, 2010
We have a customer with two UC500s in a multiple site configuration.  We are not using VPN - it is a MPLS configuration with a Windstream SIP trunk.
When a outside call comes in over the SIP trunk and a user transfers the call locally at that site, the user receiving the transferred call can see the caller ID from the original (outside) caller once the transfer is complete.  However, if the user receiving the outside call transfers it to a user at the other site, the receiving user only sees the internal extension of the senders phone even when the transfer is completed.
Any thoughts on this?
Joe
Correct Answer by antyeung about 6 years 10 months ago
Hi Joe,
Can you make sure that it's configured on both UC500's?
voice service voice
  sip
    update-callerid
Also make sure that you don't have "no remote-party-id" configured under sip-ua for both UC500's as well.
If it still doesn't work can you attach the 'show run' from both UC500's and include the 'debug ccsip message' output when you do the transfer operation?
-Anthony
Overall Rating: 5 (1 ratings)
antyeung Tue, 08/17/2010 - 01:26
  • Bronze, 100 points or more
Are you doing a blind or consult transfer?
Can you attach your 'show ver/run' output?
Anthony
Joe Gadell Fri, 08/27/2010 - 13:49
Thanks for having a look.  This happens on the consult transfer.
The configs are attached.  Remember this is a multi-site over MPLS.  The St. Louis site is the "main" office.  There is a UC520 at each end.
Thanks!
antyeung Sun, 08/29/2010 - 17:23
Looks like you are configured for SIP for intersite dialing. Can you try adding-
voice service voice
  sip
    update-callerid
Anthony
Joe Gadell Tue, 08/31/2010 - 20:25
Anthony,
I added this command.  It did not make a difference.
Any other ideas?
Joe
Correct Answer
antyeung Thu, 09/02/2010 - 19:06
Hi Joe,
voice service voice
  sip
    update-callerid
-Anthony
Joe Gadell Wed, 09/15/2010 - 18:34
Anthony,
This appears to have fixed the problem.  Thank you!
antyeung Thu, 09/16/2010 - 08:30
Good to hear!
Thanks for confirming.
-Anthony
Related Content
