08-15-2010 09:55 PM
I have a Cisco 3060 VPN concentrator and occassionally I am getting the following syslog message. What does this error mean?
Local7.Warning, SEV=2 EVENT/42 RPT=30 Save to FTP server failed(9)
Solved! Go to Solution.
08-16-2010 03:53 AM
Seems like you configure the VPN Concentrator to send saved log file to an FTP server.
You might want to check the following for the settings:
Configuration | System | Events | FTP Backup
Those are the 2 FTP options that can be configured on VPN Concentrator.
08-15-2010 10:04 PM
VPN Concentrator can be configured as an FTP server to download and upload files into the VPN Concentrator memory.
The FTP configuration is under: Configuration | System | Management Protocols | FTP
08-15-2010 11:55 PM
FTP is not enabled on the device.
08-16-2010 03:53 AM
08-16-2010 04:53 PM
Thank You, I have removed those settings. I will update you if the problems occurs again.
