CSM: HTTP probe to check health of a farm with real servers on different ports
Aug 16th, 2010
Hi Guys,
We have a farm and probe setup as follows:
probe ESS-QAT http
request method get url /irj/portal
  expect status 200
  interval 15
  failed 5
  open 5
  receive 5
serverfarm ESS-QAT
  nat server
  no nat client
  predictor leastconns
  failaction purge
   real  50100
   real  51000
  probe ESS-QAT
description decrypt VIP for ESS
  virtual tcp www
  serverfarm ESS-QAT
  persistent rebalance
  parse-length 4000
  sticky 60 group 181
My question has to do with the probe used to check the health of the servers, and more so clarify my understanding of the probes behavior.  You'll notice that the http probe doesn't have a port specified.  To my understanding (based on reading the config guide), the HTTP probe will inheret (and therefore use) the ports attached to each of the real servers when performing the GET.  That is perform a GET on and respectively.  Is this correct?
When testing this, i noticed that the probe fails on both servers...i'm hoping i don't need to configure a TCL script to check the health of the servers given this configuration.
Note, usually we have both servers recieving connections on the same port number...however in this situation each server is recieving connections on different ports.
jsirstin Tue, 08/17/2010 - 13:38
Your understanding of the probe port inheritance is correct. The CSM should be sending the probe to each of the two servers on different ports with your config. Would it be possible to get a sniffer capture of the server reply to confirm if it is giving a 200 ok response?
sgonsalv Tue, 08/17/2010 - 17:25
Thanks for the response to clarify my understanding - i'll have a closer look at the traffic flow.
