08-16-2010 01:07 AM - edited 03-06-2019 12:29 PM
I noticed this strange behaviour on my Cisco 6509.
According to the diagram attached, I have:
- A cisco 6509 Switch
- A F5 load Balancer
- An Alteon load Balancer
- A server farm
My servers are in vlan 14 connected to Alteon, and my two load balancers (F5 and Alteon) are attached to my Cisco via trunks.
The mac addresses of my servers are learned by the F5, the Alteon but not by the Cisco. Could you explain me why I 'm faced to this behaviour ?
Thank you for you help,
Julien
*** Below several usefull displays:
¤¤¤ Cisco trunk config connected to Alteon
interface Port-channel2
switchport
switchport trunk allowed vlan 1,3,14
switchport mode trunk
switchport nonegotiate
no ip address
logging event link-status
¤¤¤ Cisco trunk config connected to F5
interface Port-channel8
switchport
switchport trunk allowed vlan 14,104
no ip address
spanning-tree portfast
¤¤¤ sh etherchannel port-chan
Group: 2
Port-channels in the group:
Port-channel: Po2
Age of the Port-channel = 456d:02h:27m:05s
Logical slot/port = 14/2 Number of ports = 2
GC = 0x00000000 HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = -
Ports in the Port-channel:
Index Load Port EC state No of bits
0 55 Gi7/46 On 4
1 AA Gi7/47 On 4
Time since last port bundled: 12d:18h:44m:48s Gi7/47
Time since last port Un-bundled: 12d:18h:44m:51s Gi7/47
Group: 8
Port-channel: Po8 (Primary Aggregator)
Age of the Port-channel = 101d:01h:49m:26s
Logical slot/port = 14/8 Number of ports = 2
Protocol = LACP
0 55 Gi2/48 Active 4
1 AA Gi3/48 Active 4
Time since last port bundled: 86d:22h:16m:39s Gi2/48
Time since last port Un-bundled: 86d:22h:17m:19s Gi2/48
¤¤¤ Cisco sh vlan
VLAN Name Status Ports
14 Old-Prod- active
¤¤¤ Cisco mac-address-table
Legend: * - primary entry
age - seconds since last seen
n/a - not available
vlan mac address type learn age ports
* 14 3333.0000.000d static Yes - Gi1/4,Gi1/5,Gi1/8,Gi1/9
Gi1/10,Gi1/12,Gi1/13,Gi1/15
Gi9/45,Gi9/46,Po1,Po2,Po4
Po5,Po6,Po7,Po8,Router,Switch
* 14 3333.0000.0001 static Yes - Switch,Stby-Switch
* 14 3333.0000.0016 static Yes - Switch,Stby-Switch
08-17-2010 10:46 AM
This seems a little strange, but there has to be something more to it.
Ping the server from the switch...does it work? Regardess run:
show ip arp x.x.x.x
show mac-add add x.x.x !<---run this for the mac address that is tied to the arp you see above
Also you may just run 'show mac-add dynamic'...i think thats the right syntax. I'm not sure what you ran in your output, but its only showing some ipv6 mcast mac addresses
08-17-2010 10:04 PM
Thank you Chad for your answer,
Unfortunately , my Cisco has no Layer3 attachment in the Vlan 14, It has only a Layer2.
In the Cisco switch, I route the Vlan 14 toward my Alteon. So I can ping the servers but the mac-address in show arp command is the Alteon's mac.
I have already tried the 'show mac-add dynamic' but the list returned was empty.
Any other idea ?!
Ju
08-18-2010 09:51 AM
Thats really strange. I've seen where some loadbalancers will use a vitural mac or something of that nature...but a mac address is still learned.
Could you span the port channel and then ping. The packet capture may provide other clues. There isn't any reason this shouldn't work, thats why I'd like to see this, just to see if there is something else going on.
