Route-map policy and defalut route problem!
Aug 16th, 2010
Can any one telle me that how I can avoid that route-map policy on vlan interface to overruled the defalut route. The mening is that I want to redirect the traffic to next-hop ip add. in route-map to get to a specific destination and other wise the traffic has to use default route . Many tanks in advance!
Bedst regards SF
sfanayei Mon, 08/16/2010 - 12:29
Hi HTH
Tanks for your reply. And Yes my next-hop is directtly connected and i did tryied "set ip next-hop verify-availability" . It nearly kiled my router, I had to reboot it. Have you other suggestion that I can try.
Regards SF
