Convert remote access vpn to split-tunnel help please...
praprama Mon, 08/16/2010 - 07:55
  • Cisco Employee,
You might find the below link helpful:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702999.shtml#s2
Only modification you will need is to specify your local network (192.168.10./24) in the access-list in place of 10.0.1.0/24 in the above document.
I have linked the CLI specifically. You can find the steps to do the same using ASDM as well in the above document.
All the best!!
Thanks and Regards,
Prapanch
