08-16-2010 08:49 AM - edited 07-03-2021 07:04 PM
Hi there
we would like to configure a WLAN Workgroup Bridge with an aironet 1140 and PEAP, is this possible. Here is the actual configuration.
dot11 ssid air-secure-7
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa version 1
authentication client username xxx password 7 xxx
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid air-secure-7
station-role workgroup-bridge
bridge-group 1
bridge-group 1 spanning-disabled
Dominic
Solved! Go to Solution.
08-16-2010 09:00 AM
PEAP for WGB not supported..
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080905cea.shtml#conf
Surendra
08-16-2010 09:00 AM
Surendra
08-17-2010 12:02 AM
Hi Surendra
thanks a lot for your quick answer, this is what the Cisco Partner Helpline told me:
Thank you for contacting Worldwide Partner Helpline. My name is Marie and I will be assisting you with this case.
To answer your inquiry, yes, it is possible to configure a workgroup bridge with PEAP authentication. Kindly refer to the documentation using the link below.
PEAP under Unified Wireless Networks with ACS 4.0 and Windows 2003:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00807917aa.shtml
But now I now for sure.
Dominic
