9 Meg IMA
Aug 16th, 2010
I have a 2811 ISR running 12.4.11 T4 IOS and need to configure it for a 9 meg IMA.
I can get all of the interfaces to work but not as a Full 9 Meg.
Either as 2 - 4.5's or 1 - 6 and 1 - 3 Meg
Is there anyway to get them to work as 1 - 9 Meg IMA?
2 - ATM/AIM cards
3 - VWIC-2MFT-T1/E1
card type T1 0 0
card type T1 0 1
card type T1 0 2
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate aim 0
network-clock-participate aim 1
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
network-clock-select 3 T1 0/1/0
network-clock-select 4 T1 0/1/1
network-clock-select 5 T1 0/2/0
network-clock-select 6 T1 0/2/1
Paolo Bevilacqua Mon, 08/16/2010 - 11:17
  • Hall of Fame,
    Founding Member
Each aim-atm support up to 4 member links in a bundle. Budling across different AIM modules is  not supported, consequently the max speed using T1, is 6 mbps.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080088753.html
If you want fast service, use ethernet  / mpls, not atm ima.
