Cut-through proxy in ASA worong Timestamp
Aug 16th, 2010
I have the below hardware
ASA5510
Software :  8.0(4)
We have configured cut-through proxy. The issue is that it is integrted with ACS and both ACS and ASA are syncronized with NTP.
Now the problem is that in the cut-through proxy the time stamp it gives in the browsing webpage is something different not related to ACS or ASA timing.
The config is fine, From where the webbrowser is taking timing for login/logoff for the cut-through proxy setting.
appreciate your response.
Kureli Sankar Sat, 08/21/2010 - 16:31
  • Cisco Employee,
I am not sure I understand the question. You are asking where the browser gets its time? From the PC or active directory server that the PC users to login. right?
Or are you asking about the syslog messages that the ASA logs with the auth time stamp?
-KS
rupam_chakra1983 Sun, 08/22/2010 - 04:45
My query is the login that i see in my browser window where i enter the userid/password while using cut-through proxy,
It gives a login/logoff time in the browser which i used to authenticate ,  i am not mentioning about the syslog.
