uccx question
Answered Question
Aug 16th, 2010
we have uccx version 7.0.1 sr5. is there a setting on the server that we can customize so if a call is presented to an agent it will ring at least 5 times before it rolls to the next agent ?
as of now, the system presents the call to the agent, the phone rings 3 times and then it goes to the next available agent, we would like to increase that time
thanks
Cristobal
Correct Answer by Aaron Harrison about 6 years 8 months ago
That is as expected.
As I explained above, you need to change the timeout parameter of the Connect step in your UCCX script.
Aaron
Correct Answer by Tanner Ezell about 6 years 8 months ago
Increase the ring duration on the line in UCM.
On Mon, Aug 16, 2010 at 12:59 PM, cristobal.priego
Overall Rating: 5 (3 ratings)
Correct Answer
Tanner Ezell Mon, 08/16/2010 - 10:04
  • Silver, 250 points or more
Aaron Harrison Mon, 08/16/2010 - 10:35
  • Community Spotlight Award,
    Member's Choice, May 2015
Well - you have the 'No Answer Ring Duration' in UCM, which should be set to a longer time than the 'Connect' step 'Timeout' value
in the script. It's actually the 'Connect' step timeout value that determines how long a call rings before going to the next agent, but if the 'No Answer' timer on CCM is shorter than this you can get problems.
Aaron
Please rate helpful posts...
cristobal.priego Mon, 08/16/2010 - 11:46
hey guys, we just change the RNA timer to 60 seconds and the call is presented to the agent for 3 rings only before it bounces back to the queue
Correct Answer
Aaron Harrison Mon, 08/16/2010 - 12:58
Aaron
