can't dial out a specific 800 number
Aug 16th, 2010
hello, we have ucm 7.1.3 and a 2921 as a voice gateway
when we try to make calls to a specific toll free number we get a fast busy and if i debug the pri this is the reason code of the disconnect
*Aug 16 16:29:56.675: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8890
        Progress Ind i = 0x8388 - In-band info or appropriate now available
*Aug 16 16:29:56.931: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8890
        Cause i = 0x83AF - Resource unavailable, unspecified
        Progress Ind i = 0x8381 - Call not end-to-end ISDN, may have in-band info
sm-r2-core-rtr(config)#
*Aug 16 16:30:01.287: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0890
        Cause i = 0x8090 - Normal call clearing
*Aug 16 16:30:01.335: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8890
*Aug 16 16:30:01.339: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0890
*Aug 16 16:30:02.975: ISDN Se0/2/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x888B
*Aug 16 16:30:02.975: ISDN Se0/2/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x088B
*Aug 16 16:30:02.995: ISDN Se0/2/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x888B
sm-r2-core-rtr(config)#do un all
Paolo Bevilacqua Mon, 08/16/2010 - 10:43
  • Hall of Fame,
    Founding Member
Check calling number plan/type. Must be isdn/national 10 digits.
In teh future, always include the complete call setup trace, not just what you deem is relevant.
bruce.williams@... Fri, 07/22/2011 - 09:13
We are having the exact same issue. We are having a problem dialing only specific 800 numbers. We are receiving the same error code.
Jul 22 11:56:26.060: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8032
HOU2851#
Please tell me how you resolved this.
Bruce
Clifford McGlamry Fri, 07/22/2011 - 20:09
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
Toll free numbers are unique in their handling requirements.  If you have both local telco connections and dedicated LD connections, you will find that you can hand of *SOME* toll free traffic, but not all, on the dedicated LD circuit.
The reason for this is that unless the LD carrer you are attached to is servicing that 800 number, they will have no idea where to send it.
Toll free calls should be routed out via the LOCAL telco connection.  The local telco can do a lookup to see who the toll free number is PIC'ed to, and forward it to the appropriate LD carrier for termination.
If you send it to the LD carrier, and they don't terminate that 800 number (i.e. another carrier is servicing it), you'll get the error you are describing.
Cliff
Please rate helpful posts
Clifford McGlamry Fri, 07/22/2011 - 20:10
Also, some toll free numbers are restricted in that they can only be dialed from certain areas.  If you hit a restriction like this, you very well might see this error as well.
Cliff
