Network VRU Script *Configuration Parameters*
Aug 16th, 2010
ICM 7.x
Can anyone direct me to a guide that tells you the specific paramters for a Network VRU Script??
I am running the microapp "Get Digit" and the timeout is taking too long.  Meaning - I am wiating for the caller to enter some digits - could either be single or multiple digits (3) and after you enter the digits the time it takes to move on is a little too long.
More to the point - in the configuration paramters field - it has (3,3,N,3,3,1,1)
It would help to understand what each of those digits represents - I know the first (or second) represents the number of digits to expect - but no clue on the rest.
In context - the caller can either enter a single digit menu option OR a 3 digit code off the main menu - after I collect the digits - I check if there are multiple digits then route to different CED nodes.  The issue bieng that it seems to wait 5 seconds after the last digit is pressed before proceeding in the script.
Any ideas?  Thanks in advance!!!
Overall Rating: 4 (1 ratings)
