ipsec site-to-site VPN and cisco VPN client routing problem
Answered Question
I am really stuck with configuring ipsec site-to-site vpn (hub to spoke, multiple spokes) with cisco vpn client remote access to this vpn.
The problem is with remote acces - cisco vpn client acces - I can communicate with hub lan - but I need also communication to all spoke lans from the cisco vpn client.
On the spokes there is no cisco hardware used - there are DLINK routers.
Somebody told me, it is possible to use NAT for translating remote access clients to HUB-lan-IP and so allow communication - but I am unable to configure it and get it working.
Can somebody help me please ?
Thank you
Peter
SPOKES - not cisco devices / another vendor
HUB cisco 1841 hsec:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key x address xx no-xauth
crypto isakmp client configuration group x
key x
pool vpnclientpool
acl 190
include-local-lan
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set 1cisco esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set 1cisco
crypto map ETH0 client authentication list userauthen
crypto map ETH0 isakmp authorization list groupauthor
crypto map ETH0 client configuration address respond
crypto map ETH0 1 ipsec-isakmp
set peer x
set pfs group2
match address 180
crypto map ETH0 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/1
description $ES_WAN$
crypto map ETH0
ip local pool vpnclientpool 192.168.200.100 192.168.200.150
ip nat inside source list LOCAL interface FastEthernet0/1 overload
ip access-list extended LOCAL
deny   ip 192.168.7.0 0.0.0.255 192.168.1.0 0.0.0.255
deny   ip 192.168.7.0 0.0.0.255 192.168.200.0 0.0.0.255
permit ip 192.168.7.0 0.0.0.255 any
access-list 180 permit ip 192.168.7.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 190 permit ip 192.168.7.0 0.0.0.255 192.168.200.0 0.0.0.255
Correct Answer by Jennifer Halim about 6 years 6 months ago
How was the DLINK configured for the traffic between the site-to-site VPN subnets? Are you able to add multiple remote subnets on DLINK? If you can, then you need to add the VPN Client pool subnet.
Alternatively, if you can't add multiple subnet on DLINK router, you can change the VPN Client pool to 192.168.6.0/24, and on the crypto ACL between the site-to-site VPN, you need to change the existing ACL 180
access-list 180 permit ip 192.168.200.0 0.0.0.255 192.168.1.0 0.0.0.255
TO:
access-list 180 permit ip 192.168.6.0 0.0.1.255 192.168.1.0 0.0.0.255
Then also change the split tunnel ACL 190:
access-list 190 permit ip 192.168.1.0 0.0.0.255 192.168.200.0 0.0.0.255
TO:
access-list 190 permit ip 192.168.7.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 190 permit ip 192.168.1.0 0.0.0.255 192.168.6.0 0.0.0.255
Lastly, change the DLINK remote subnet from 192.168.7.0/255.255.255.0 to 192.168.6.0/255.255.254.0.
Hope that helps.
Overall Rating: 5 (2 ratings)
Jennifer Halim Mon, 08/16/2010 - 14:46
The crypto ACL both for the site-to-site VPN and split tunnel ACL for the Cisco VPN Client needs to be added with the respective ACL line.
Base on the configuration, I believe you have the following:
Local subnet: 192.168.7.0/24
Remote subnet: 192.168.1.0/24
VPN Client subnet: 192.168.200.0/24
ACL 180 is used for the site-to-site VPN crypto ACL, you would need to add the following:
On the remote DLINK router, you would also need to add the corresponding mirror image ACL:
access-list xxx permit ip 192.168.1.0 0.0.0.255 192.168.200.0 0.0.0.255
Then on the split tunnel ACL: 190, you would also need to add the following:
Hope that helps.
thank you for your help. I have altered the ACLs:
deny  ip 192.168.7.0 0.0.0.255 192.168.1.0 0.0.0.255                 local lan – remote lan A
deny   ip 192.168.7.0 0.0.0.255 192.168.200.0 0.0.0.255                 local lan – vpn client
deny ip 192.168.200.0 0.0.0.255 192.168.1.0 0.0.0.255                 vpn client – remote lan A
access-list 190 permit ip 192.168.7.0 0.0.0.255 192.168.200.0 0.0.0.255 local lan – vpn client
access-list 190 permit ip 192.168.1.0 0.0.0.255 192.168.200.0 0.0.0.255 remote lan A – vpn client
access-list 180 permit ip 192.168.7.0 0.0.0.255 192.168.1.0 0.0.0.255                 local lan – remote lan A
access-list 180 permit ip 192.168.200.0 0.0.0.255 192.168.1.0 0.0.0.255 v pn client – remote lan A
But I cannot reach the remote lan A from the cisco vpn clients.
The remote lan routers are not cisco devices - they are low end DLINK VPN routers with web gui. I cannot configure the reverse ACL on them. I think thats the problem.
Is it somehow possible to use NAT to translate remote acces vpn clients to local lan IP and so reach the remote lan A ?
Thank you
Correct Answer
Jennifer Halim Tue, 08/17/2010 - 01:29
TO:
TO:
Hope that helps.
