Pix 515e 6.3(4) Local user question
Answered Question
Aug 16th, 2010
I was wondering if anyone would be able to tell me if there is a limit to the number of unique vpn connections a  pix 515 6.3 can terminate for the same local user account. So, basically will it work if 10 or 20 or even more users use the same local user account to setup up a vpn connection to the device at the same time?
Thanks in advance.
Correct Answer by JORGE RODRIGUEZ about 6 years 6 months ago
If you look at tabel 1, under performance summary  the maximun Ipsec sessions is 2000   for 515E firewalls -   see  "  Simultaneous VPN tunnels: 2000 "
Each RA vpn client connection counts towards this number, L2L VPN session also counts as well.  So to answer your question , if a username   VPNs-in  from three different external  locations that  will be three different simultaneous IPsec tunnels.
Im not sure on 6.3.5 code , but in code 7.x above you can limit the number of simultaneous  RA VPN  connections per user I believe for example  to only  one  connection , if that is what you are looking into .
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5708/ps5709/ps2030/ps4094/product_data_sheet09186a0080091b15.html
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Mon, 08/16/2010 - 14:21
wvwavere01 Mon, 08/16/2010 - 14:40
Ok, thanks, that kind of answers my question. I just wanted to
be sure that there were no limits on the number of
connections per user account, only  the limits set
by the licence.
