MGCP gateway in SRST mode, incoming calls not routing.
Answered Question
Aug 16th, 2010
I have an MGCP gateway (1861) with SRST configured for WAN failure. There is BRI line connected to it and has a number 3709 3416. The extension numbers in the building are 8XXX (around 13 telephones).
in MGCP mode I have a translation pattern to translate the incmoning calls to 8XXX extensions and all works fine. during WAN failure (simulated) 1861 goes in SRST mode and 8 phones register to it randomly. during this, the incoming calls dont work. outgoing are fine. I have dial peer configured and translation rule for incoming also,
Can anyone help with the troubleshooting?
Here is SRST and dial peer confing
voice translation-rule 1
rule 1 /37093416/ /8904/
voice translation-profile SRST
translate called 1
voice-card 0
application
global
  service alternate default
dial-peer voice 1 pots
translation-profile incoming SRST
destination-pattern 0T
incoming called-number .
port 0/1/0
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.0.218 port 2000
max-ephones 8
max-dn 14 dual-line
time-format 24
Any help is appreciated
Thanks and Regards
Shruti
Correct Answer by techguy73 about 6 years 10 months ago
try to modify your pots dialpeer as follows
dialpeer voice 22 pots
direct-inward-dial
and remove the profile from the call-manager-fallback. Test it out.
if this helpful, plz rate the post.
cheers
Overall Rating: 5 (1 ratings)
maquan_cco Mon, 08/16/2010 - 18:00
Maybe you should take good cara of the Status of Callmanager MGCP gatway  Cause MGCP will turn to Callmanager For Routing Calls.
And you can
show call-manager-fallback
confi ter
no mgcp
mgcp
to see if can be OK
You should lookup on MGCP troubleshoot fr cisco.com
shrutid22 Mon, 08/16/2010 - 19:00
Thanks for the quick reply. but the problem is in SRST mode not in MGCP.
what do you think?
thanks
Correct Answer
techguy73 Mon, 08/16/2010 - 20:53
  • Bronze, 100 points or more
direct-inward-dial
cheers
