SIP Phone not appearing under CUCME GUI 7.0(1)
Answered Question
Aug 16th, 2010
I'm having an issue with the CUCME GUI. I've 4 ip phones configured as 2xSCCP && 2xSIP. Both the SCCP phones&lines appear under the GUI correctly but not for the 2xSIP phone&line.
Spec info: Cisco 2811 with NM-CUE, IOS: 12.4(22)T2, GUI: 7.0.(1)
One of the voice register dn has configured as x3005 under CLI. I tried created the x3005 under GUI since it doesn't appear under GUI and end up the system created an ephone-dn with x3005.  Is the GUI can only manage SCCP?
Orochi
Correct Answer by roger.kallberg about 6 years 9 months ago
The answer to your question "Is the GUI can only manage SCCP?" is yes. The CUCME GUI for 7.0(1) is only capable of supporting SCCP phones.
Best regards
Roger Kallberg
CCIE # 26199 (Voice)
Overall Rating: 5 (1 ratings)
Correct Answer
roger.kallberg Tue, 08/17/2010 - 01:47
  • Silver, 250 points or more
Best regards
Roger Kallberg
