Antivirus in Ciscoworks Server
Aug 16th, 2010
Hi is there any dependacies of LMS 3.2 with Antivirus like Symantec end point protection? I want to to install Symantec end point protection in my LMS server. Will it impact on any of the feature of LMS?
ngoldwat Mon, 08/30/2010 - 10:55
Generally, the advice concerning anti-virus software is:
1. Completely disable during LMS installation
2. Exclude everything under CSCOpx from real-time scans
It is possible that additional settings will impact LMS so I suggest a look and see approach. Try enabling the feature and watch the event logs for problems. If the software has a 'warn' only option enable that first. It should give you a good idea of what it is doing.
