Wireless rate limit
Aug 17th, 2010
My network infrastructure as simple as following:
LAN(edge switches 3560).......>Aggregator switch(3750)........>Firewall(ASA 5510)........>Router.......>Internet
I define 3 wireless VLANs with 3 SSIDs on the Aggregator switch(3750):
1. one SSID for company employees.
2. one SSID for wireless IP phones.
3. one SSID for company guest which access only internet.
And the wireless APs connected to the LAN(edge switches) direct with trunks.
My question is how to apply a rate limit for SSID for company guest to access internet with B.W. of 128kbps only.
I tried policy map to be applied on the aggregator switch(3750) on the VLAN interface, but, it is not working.
So, any suggested help, please.
Leo Laohoo Thu, 11/18/2010 - 20:37
WLAN > SSID > QoS tab > QoS
To set the value of your QoS to to Wireless > QoS > Profiles.
Please don't forget to rate our useful posts.  Thanks.
