Problem to add the 2nd IPCC 7.0.1 node to the Cluster‏
Aug 17th, 2010
Am getting the below error message during setup/adding the 2nd IPCC node to the cluster (ver 7.0.1)
Add to Cluster is failed becuase of ClusterException invalid icdLang: LocalNode=English , remoteNode=Finnish
Although the lang at the 1st node is English, Any idea for this ...
joesnyde Tue, 08/17/2010 - 04:33
Hi Wael,
Did you at some point change any language settings on the first node to Finnish? Such as the Operating System Regional and Language Options? Is this particular OS the same media as the first node?
This is fixable, however are you familar with the cet tool?
Thank you,
