08-17-2010 03:13 AM - edited 03-16-2019 12:17 AM
I am using CUCM version 7. Unity express version 7.0. In normal operation all of my configuration is working fine. On SRST from PSTN/Mobile any one can call inside and here atoattendant welcome message and the call can be transferred to any IP Phone.
The issue is while all the IP Phone are on SRST I am unable to dial any PSTN/Mobile number. Also internal calls are not going to voice messages.
I have attahed the running configuration of the Voice Gateway and "debug voice ccapi all" logs on SRST.
call manager ip 172.21.131.162
Voice Gateway ip 10.76.90.254
Unity Express ip 10.76.90.253
Please help me to troubleshot the issue.
Ashfaque.
Solved! Go to Solution.
08-17-2010 07:26 AM
Calls are failing with no circuit on the outbound dial-peer match to go out the trunk group. Is the POTS trunk group up, and are these circuits active and able to take outbound calls? Can you plug an analog phone into these circuits and make outbound calls?
Collect the CCAPI debug again in addition to 'debug vpm sig' in parallel, and you can observe what events are occurring on the analog circuits to trigger the no-circuit.
-Steve
08-17-2010 07:26 AM
-Steve
08-18-2010 08:00 AM
Thanks Steve, four circuits were causing problem. Have changed those circuits now it is working ok.
Ashfaque
