Software DSP
Answered Question
Aug 17th, 2010
Hi all experts. This question may be broad but since i have heard this term i thought i should know it as i progress in my voice studies.
What are software DSPs ? i know about HW DSPs like PVDM (2nd generation etc), but do we have software DSP in
1) Router like 2800, 2600 etc
2) CUCM (any version)
Can someone pls refer me a document that explain software DSPs in detail ? or any cisco press ebook ?
thanks alot in advance
Correct Answer by Jaime Valencia about 6 years 11 months ago
There really are no SW DSPs, what you can do using SW and not HW DSPs is to create a SW MTP using IOS resources and in CUCM you get MTPs (with limited capabilities) and the SW CFB (again, limited capabilities). Unity can do some XCODING and use G729 but it's recommended you do this in HW because takes a lot from the CPU and resources from the server.
For CUCM the maximum values for each are already defined and cannot be increased unless you have a standalone server.
For IOS there are baseline values but they depend on what the ISR is already doing and how much load it has to know the real maximum you can set at any given point in time.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 08/17/2010 - 06:22
  • Cisco Employee,
  • Hall of Fame,
    2011
java
