measure network bandwidth consumed by a pc
Aug 17th, 2010
HI,
I want to measure and monitor how much bandwidth a pc consumes , when a user enters his username and password  annd passes nac and conencts  to the access  network
How can I monitor and check that activity and how much data exchnage takes place  ?
Once the PC is up and user enters the  AD  credentials and then it passes NAC and then goes to the authentciated vlan role , .
I tried to check in NAM , but  not available .
Any help is appreciated
Panos Kampanakis Mon, 09/13/2010 - 08:38
  • Cisco Employee,
To add to Ben's suggestion.
If you have an IOS router that the user goes through, or an ASA, you can use Netflow and the Netflow collector can give you statistics on traffic the user generates.
I hope it helps.
PK
