vpn 3008 remote access
Aug 17th, 2010
any tip of vpn 3008 remote access configuration,I configured it but it's given error (Reason 412 the remote peer is not longer responding but there is no firewall,just trying it without firewall before puting behing firewall.
Asim Malik Tue, 08/17/2010 - 10:15
If the remote clients are connecting over patting device then NAT-T need to be enabled on concentrator. What version of VPN client you are using? Can you provide logs from teh VPN client set to debug level(3). Did you tried with multiple machines? What is the OS?
Check this for config examples
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2284/prod_configuration_examples_list.html
selomedake Tue, 08/17/2010 - 12:43
Find attached the logs from the client nad there is no firewall I just connect to public network and trying it before putting it behind firewall.
Asim Malik Wed, 08/18/2010 - 10:12
There are no logs in the file. Probably you havent enabled the logging or havent tried to connect after the logging was enabled
