Upgrade UCM 4.1(3) to UCM 8.0(3)
Answered Question
Aug 17th, 2010
we would like to upgrade our UCM cluster from release 4.1(3) to 8.0(3) using new hardware. Unfortunately there is no DMA tool available on cisco.com to migrate configuration and no specific upgrade guide from release 4 to 8. Does anybody have some experience for such an upgrade?
thanks in advance
Gundolf.
Correct Answer by Rob Huffman about 6 years 9 months ago
Hi Gundolf,
Sadly, there is no direct upgrade path between any 4.x CCM to
CUCM 8.x as shown below;
Table 4     Supported Cisco Unified Communications Manager Upgrades for Release 8.0(x)
8.0(3)
8.0(2c)SU1
8.0(2c)
8.0(1)
System Version
8.0.3.10000-8
8.0.2.41900-3
8.0.2.40000-1
8.0.1.10000-40
Release Date
Jul 27 2010
Jul 8 2010
May 6 2010
Feb 26 2010
Standard Support
Direct upgrade:
8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a)SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 7.0(1)SU1a, 7.0(1)SU1, 7.0(1), 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 6.1(2)SU1a, 6.1(2)SU1, 6.1(2)
Direct upgrade:
Direct upgrade:
Direct upgrade:
Direct upgrade using DMA:
none
none
none
none
From this excellent doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp184796
You would have to complete a "two-hop" upgrade to 6.x or 7.x as an intermediate step
FYI - many people are holding off going to CUCM 8.x due to the number of bugs.
Cheers!
Rob
Overall Rating: 5 (3 ratings)
Correct Answer
Rob Huffman Tue, 08/17/2010 - 06:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Gundolf,
8.0(3)
8.0(2c)SU1
8.0(2c)
8.0(1)
System Version
8.0.3.10000-8
8.0.2.41900-3
8.0.2.40000-1
8.0.1.10000-40
Release Date
Jul 27 2010
Jul 8 2010
May 6 2010
Feb 26 2010
Standard Support
Direct upgrade:
Direct upgrade:
Direct upgrade:
Direct upgrade:
none
none
none
none
Cheers!
Rob
Jaime Valencia Tue, 08/17/2010 - 06:44
  • Cisco Employee,
  • Hall of Fame,
    2011
That's because there is no direct upgrade from any Windows version. You need to be in 6.1 o 7.0 for that upgrade.
EDIT: once again you beat me Rob, should avoid replying until I get a cup of coffe to really wake up =)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
GUNDOLF ANDERS Tue, 08/17/2010 - 06:49
Hi Rob, hi Java,
many thanks for the quick answers.
Best regards
Gundolf.
bernhardczapp Tue, 10/19/2010 - 02:20
  • Bronze, 100 points or more
Hello all,
i've one more question regarding the upgrade 4.1(3) to 8.x.
Is there a possibility to purchase a upgrade license or do you have to buy everything new with UCL or CUWL?
So can I use the 3&3 upgrade program or is there an other possibility?
Bernhard
GUNDOLF ANDERS Tue, 10/19/2010 - 03:23
Hi Bernhard,
you can use the 3 x 3 offer to upgrade from 4.x to 8.0x.
Starting from the CUCM-USR you than configure into this container migration users.
Gundolf.
bernhardczapp Thu, 10/21/2010 - 01:50
That would be great because it's much cheaper.
Where did you find this information?
Bernhard
bernhardczapp Mon, 02/14/2011 - 00:01
It's not really a problem, is it?
The point is, that there is no DMA-Tool any longer starting with CUCM 8.x
So if you want to migrate Devicelicenses and the configuration from a windows version you have to do a 2 step upgrade.
Step 1) Use DMA-Tool to get to any Version from where you can upgrade to 8.x
Step 2) Upgrade to 8.x
